Axle's out now what
gonzo891
i removed my axle and i'm now wondering how i should get the hub off the end. i know i could go to a shop and pay to have it done but i was wondering if there is a back yard/garage way that might save me some time and money.[addsig]
1056291
36mm socket and impact wrench to remove the axle nut, then slide the bearing assembly off.[addsig]
1056379
Once you have the nut off, use a 2 or 3 jaw puller to get the hub off. $25.00 at Autozone.[addsig]
1056407
He's already removed the axle, so the puller won't work. Just has to remove the axle nut and the bearing assembly slides off the shaft.
The puller would work if the axle was still installed in the housing.[addsig]
