superj
Active member
back in trouble again, no start--- fixed!!!!!
same as last weekend but cleaning all the connections didn't help. i also have changed the starter (again, bad bendix bar thing, it doesn't return completely), solenoid, and power and ground wires). i didn;t replace the battery because i bought it two months ago but we are going to test it tomorrow morning at the oreilly's.
anyone happen to have a starting system wiring diagram?
-------------- fix below ---------------------
Solenoid had a bad connection to the firewall not allowing the little switch to close and pull the jumper up that powers the starter. Once I cleaned the threads and ran the mounting bolts down good, the jeep fired up, just like normal
