i know the usuall boken u-joint replacement, but this time i snapped the shaft at the splines and i tried the magnet trick to no avail. i pulled the front diff cover only to see that i would need to pull my locker to get to the inside of the shaft splines..this is the drivers side shaft and it broke off just about 2 inches out from the splines....any tricks
i was thinking of removing the other shaft and try running a long metal dowel, but i think the "locker center pin" might prevent this...
it is the d-30 axle with tj shafts and a lockrite???? :shock:
