The P0200 code still refers to the injector circuits. The absence of the P0300's means there's no misfire detected with the injector dtc. I'm thinking the issue is still within the input circuit of the injector.
MODES OF OPERATION
As input signals to the powertrain control module (PCM) change, the PCM adjusts its response to the output devices. For example, the PCM must calculate different injector pulse width and ignition timing for idle than it does for wide open throttle (WOT)
The PCM will operate in two different modes:
Open Loop and Closed Loop.
During Open Loop modes, the powertrain control module (PCM) receives input signals and responds only according to preset PCM programming. Input from the oxygen (O2S) sensors is not monitored during Open Loop modes.
During Closed Loop modes, the PCM will monitor the oxygen (O2S) sensors input. This input indicates to the PCM whether or not the calculated injector pulse width results in the ideal air-fuel ratio. This ratio is 14.7 parts air-to-1 part fuel. By monitoring the exhaust oxygen content through the O2S sensor, the PCM can fine tune the injector pulse width. This is done to achieve optimum fuel economy combined with low emission engine performance.
The fuel injection system has the following modes of operation:
- Ignition switch ON
- Engine start-up (crank)
- Engine warm-up
- Idle
- Cruise
- Acceleration
- Deceleration
- Wide open throttle (WOT)
- Ignition switch OFF
Based on this modes of operation, the symptom seems to occur after it has reached the closed loop mode since you drove it for about 6 miles before the DTC (P0204) came back.
ENGINE WARM-UP MODE
This is an Open Loop mode. During engine warm-up, the powertrain control module (PCM) receives inputs from:
- Battery voltage
- Crankshaft position sensor
- Engine coolant temperature sensor
- Intake manifold air temperature sensor
- Manifold absolute pressure (MAP) sensor
- Throttle position sensor (TPS)
- Camshaft position sensor signal (in the distributor)
- Park/neutral switch (gear indicator signal - auto. trans. only)
- Air conditioning select signal (if equipped)
- Air conditioning request signal (if equipped)
Based on these inputs the following occurs:
- Voltage is applied to the fuel injectors with the ASD relay via the PCM. The PCM will then control the injection sequence and injector pulse width by turning the ground circuit to each individual injector on and off.
- The PCM adjusts engine idle speed through the idle air control (IAC) motor and adjusts ignition timing.
- The PCM operates the A/C compressor clutch through the A/C compressor clutch relay. This is done if A/C has been selected by the vehicle operator and specified pressures are met at the high and low - pressure A/C switches. Refer to Heating and Air Conditioning for additional information.
- When engine has reached operating temperature, the PCM will begin monitoring O2S sensor input. The system will then leave the warm-up mode and go into closed loop operation.
IDLE MODE
When the engine is at operating temperature, this is a Closed Loop mode. At idle speed, the powertrain control module (PCM) receives inputs from:
- Battery voltage
- Battery voltage
- Oxygen sensors
- Power steering pressure switch (2.5L engine only)
Based on these inputs, the following occurs:
- Voltage is applied to the fuel injectors with the ASD relay via the PCM. The PCM will then control injection sequence and injector pulse width by turning the ground circuit to each individual injector on and off.
- The PCM monitors the O2S sensor input and adjusts air-fuel ratio by varying injector pulse width. It also adjusts engine idle speed through the idle air control (IAC) motor.
- The PCM adjusts ignition timing by increasing and decreasing spark advance.
On 2.5L 4 - cylinder engines, a power steering pressure switch is used to supply an input to the PCM when steering pump pressure is high. This will raise engine speed. Refer to Power Steering Pressure Switch in this group for additional information.
The 4.0L 6 - cylinder engine does not use this switch.
CRUISE MODE
When the engine is at operating temperature, this is a Closed Loop mode. At cruising speed, the powertrain control module (PCM) receives inputs from:
- Battery voltage
- Oxygen (O2S) sensors
- Voltage is applied to the fuel injectors with the ASD relay via the PCM. The PCM will then adjust the injector pulse width by turning the ground circuit to each individual injector on and off.
- The PCM monitors the O2S sensor input and adjusts air-fuel ratio. It also adjusts engine idle speed through the idle air control (IAC) motor.
- The PCM adjusts ignition timing by turning the ground path to the coil on and off.
- The PCM operates the A/C compressor clutch through the clutch relay. This happens if A/C has been selected by the vehicle operator and requested by the A/C thermostat.
- The Up-shift Indicator Lamp is operated (manual transmission only)
ACCELERATION MODE
This is an Open Loop mode. The powertrain control module (PCM) recognizes an abrupt increase in throttle position or MAP pressure as a demand for increased engine output and vehicle acceleration. The PCM increases injector pulse width in response to increased throttle opening.
DECELERATION MODE
When the engine is at operating temperature, this is an Open Loop mode. During hard deceleration, the powertrain control module (PCM) receives the following inputs.
- Battery voltage
- Vehicle speed sensor
If the vehicle is under hard deceleration with the proper rpm and closed throttle conditions, the PCM will ignore the oxygen sensor input signal. The PCM will enter a fuel cut-off strategy in which it will not supply a ground to the injectors. If a hard deceleration does not exist, the PCM will determine the proper injector pulse width and continue injection.
Based on the above inputs, the PCM will adjust engine idle speed through the idle air control (IAC) motor.
WIDE OPEN THROTTLE MODE
This is an Open Loop mode. During wide open throttle operation, the powertrain control module (PCM) receives the following inputs.
- Battery voltage
During wide open throttle conditions, the following occurs:
- Voltage is applied to the fuel injectors with the ASD relay via the PCM. The PCM will then control the injection sequence and injector pulse width by turning the ground circuit to each individual injector on and off. The PCM ignores the oxygen sensor input signal and provides a predetermined amount of additional fuel. This is done by adjusting injector pulse width.
With this information, we can eliminate some of the variables thats not a possible source of the DTC. From what i see, the possible components in question here would be as follows:
Injector pulse circuit from the PCM(wiring)
CKP or the reference tone ring of the sensor
CMP or its reference tone ring
PCM
Since you have already swapped the injector from another cylinder and the DTC is STILL in the same position, i would eliminate the injector itself to be the possible cause. Out of all the sensors involved in the modes of operation that's relevant to the function and command of the fuel injection system, I would also eliminate the O2 sensors, Map sensor, IAT sensor, safety neutral switch, ECT sensor, battery voltage, TPS, powersteering pressure switch from the possible cause of the DTC.
If i was to troubleshoot this issue, i would start with the wiring for the process of elimination.
I can walk you through the wiring diagram if you wish but you have to do the dirty work and find the wiring involved on the injector #4 circuit. The PCM wiring can be intimidating but if you follow the wiring color code and with the use of a DMM(digital multimeter) , you should be able to find and verify that the wiring passes the test.
