check engine light
luis
I keep getting the same code over and over again iv replaced the o2 sensors. The map sensor tps is working cuz I disconnect them and a code comes up. I check the exhaust and no cracks or leaks the only questionables were the egr block off plate had a bad gasket so I replaced that and even placed exhaust sealer as an added protection. Also I can c a black line that looks like an exhaust leak but that's right after the cat and after the number 2 o2 sensor. Vacuum reading is 26.2, fuel pressure at key on (no start) is 20psi and at start is around 28-35 psi. Pump works cuz I can hear it whin when I turn the key on.. I'm completely stumped
