I have 2 lines from my disengage unit on the right side of the front diff.that are broke. Question is can I use 1/4 or 1/8 inch rubber hose instead of the plastic lines? Any commemnts are welcome.
In a pinch, you can remove the vacuum disconnect from the axle (4 bolts), flip it upside down and reinstall it. It will then hold the disconnect in the 'engaged' position so you have 4wd.
