GenRight Closeout - limited quantities selling fast!
GenRight Off Road
Here is a list with pictures of items we currently have on closeout.....these are limited items (in some cases only one) on close-out with all sales final. Order now if you see something you like as we do not know how long they will remain on closeout!
Call Andrew, Closeout Sales Representative, at 805-584-8635! :beer:
VDP Super Siphon
The Patented Super Siphon is a self-priming siphoning device with 5 feet of hose. It is easy to use and eliminates the need to suck on the end of a hose to start siphoning. Great for transferring gasoline from a vehicle to a container or from a container to 4 x 4, Jet Ski, Motorcycle, etc. Moves 1.6 gallons per minute.
Factory TJ Hood
This is a mint condition factory Jeep TJ (or LJ) hood off a silver 2005 Jeep.
Key Features:
All Steel construction
Comes painted silver (paint code PSB)
This is a CLOSEOUT item and this offer is good for this one hood.
Factory gas tank and skid, 05-06 TJ/LJ
Used Factory Gas Tank and Skid, 05-06 TJ/LJ
This is a CLOSEOUT item and this offer is good while supplies last.
Jeep Tail Light, TJ
A single Jeep tail light for Stop, turn, and night lights. Originally off a Jeep TJ and a great spare or replacement for damaged lights so you don't get pulled over.
Savvy rear bumper w/2" receiver hitch, TJ/LJ
This is a Savvy Brand aluminum rear bumper for a Jeep TJ/LJ with a 2" receiver tow hitch.
It has been powder coated semi gloss black and is in perfect condition, as pictured.
It was a "take off" from a customer build here at GenRight.
Rugged Ridge chrome front bumper, TJ/LJ/YJ
This is a front bumper that will fit a Jeep TJ, LJ, or even YJ made by Rugged Ridge. It is made from a pair of large diameter tubes with another tube acting as a loop to protect your winch or grill.
Rugged Ridge rear bumper w/2" receiver hitch, TJ/LJ/YJ
This is a rear bumper that will fit a Jeep TJ, LJ, or even YJ. It has a mount with a 2" receiver tow hitch that attaches the chrome tube bumper to the Jeep.
TJ stock chrome step rails
A set of stock TJ chrome sliders. This is a great set to replace damaged TJ sliders or be a spare in case your offroad adventure becomes a little too treacherous. Each has a rubber step in the center to help as a step into the vehicle. The tubular construction holds up well when bashed against rocks or dips and they will not snag on rocks!
5 x 2013 take-off Rubicon wheels and tires
This is a set of (5) 2013 Jeep Wrangler JK RUBICON "take off" tires and wheels!
Tires: BF Goodrich Mud Terrain
Wheels: Jeep JK Rubicon 17"x 7.5" alloy wheels.
The stock Jeep Rims are in perfect condition and have only 13 miles on them!
The tires are new with the injection rubber "nipples" still on parts of the tire.
Standard Jeep JK bolt pattern, 5 on 5.
Full Race Currie Rock Jock 60 Front Axle
This is a slightly used full race Currie Rock Jock 60 front axle out of the 4485 Ultra4 race buggy. The unit was a back up unit and is "fresh" and ready to run! Over $10,000 invested in this top of the line front axle.
Hi-pinion Dana 60 front axle
5.13 gears, new
ARB locker, new
1350 yoke
300m axle shafts
CTM U-joints
Currie 4340 RACE unit bearing hubs with 5/8" studs (5 on 5.5)
Forged aluminum knuckles
Fully gusseted for strength
HD mounts for double triangulated 4 link suspension
Mounts for HOWE 2.25" full hydro ram
65" WMS to WMS
Designed to fit 13.8" brake rotors (brake calipers not included for this price)
Front JK D30 stock axle
Factory JK Dana 30 Front Axle. Was in perfect working order when removed. Complete with brakes and steering.
Factory JK D44 Rear Axle
Factory JK Dana 44 Rear Axle. Was in perfect working order when removed. Low original miles.
Complete with rear brakes and trac bar.
TJ Dana 30 Front Axle
This is a Front Dana 30 set up for a Jeep TJ/LJ. It has a 4.88 ring and pinion, with an ARB locker.
Product Specs:
Factory Dana 30 front axle.
All factory brackets for a Jeep TJ/LJ
4.88 Gear Ratio
ARB locker
Factory TJ Dana 35 Rear Axle
This is a take out axle with less than 35,000 original miles.
Factory TJ Dana 35 Rear. 3.07 Gears
Eibach Coil Springs, Each
This is Eibach brand Coil Spring to fit any 2" diameter coil over shock (techinecially 2-1/2" diameter).
Trademark Red color.
These are left over inventory and still NEW and IN THE BOX!
Normally $73.00 each and a super good deal at this price!
Used Winch Cable
This is a brand USED winch cable from a Warn 8000lb rated winch. Great as a back up winch line!
SPEC: 5/16" x 80'
Over $150 new a super good deal at this price!
Perforated, G2 Side Panel Hi-Fender, Pr.
This is the PERFORATED removable panel for the GenRight Tube Fenders. This is an upgraded from the standard "plain" side panel that comes with every one of our G2 Hi-Fender Tube Fenders.
FEATURES:
Perforated holes vent unwanted head from the engine compartment.
Fits all G2 Hi-Fender Tube Fenders.
Made of corrosion resistant Aluminum.
Sold in a brushed aluminum finish.
Held in place with 4 stainless allen bolts (sold separately).
Nuts are pressed into the back of each side panel.
Sold in pairs.
Holley 120-146 - Power Shot Chrome Air Filter
Holley 120-146 - Power Shot Chrome Air Filter New in box.
Air Filter Assembly, 14 in. Diameter, Round, Steel/Chrome, Holley Logo, 3 in. Filter Height, Each
Includes only what is pictured.
Rock Krawler Coilovers with Reservoir pair w/out Springs
Rock Krawler Coilover with Reservoir w/out Springs, Pair Shocks
-Hard annodized aluminum fluted shock body.
-Best cooling emulsion shock in the industry.
-Lightest weight shock in its class.
-1” Nitrotec Steel shaft.
-Viton o-ring and double lip Buna N shaft seals.
-Billet aluminum valve circuit with digressive valving.
-High quality shock therapy oil.
-Moly piston wear band.
-Serviceable, rebuild-able, re-valve-able, completely tune able by the factory or the do it your selfer!
-Remote reservoir with internal floating piston!
-No springs included.
Wilwood 12-11/16" Dia Rotors, Pair (Left & Right)
Diameter: 12.72 Width: 1.25 Rotor Bolt Circle(s): 8 x 7.62 GT 48 Curved Vane Rotor
Wilwood's GT 48 Curved Vane Spec-37 rotors are manufactured from a proprietary iron alloy developed to withstand extreme temperatures with the highest possible degree of resistance against distortion, warping, cracking, and wear. The formulation for this alloy is a derivative of technology and materials that were significant in the development of the extreme duty military spec rotors that are manufactured by Wilwood. Every Spec 37 rotor is precision machined to less than .001" run-out, flatness, and parallelism. Combined with our proven GT Series asymmetrical face slot pattern and individual dynamic balancing, you are assured the smoothest braking available.
Wilwood 14" Rotors, Pair (Left and Right)
Diameter: 14 Width: 1.25 Rotor Bolt Circle(s): 12 x 8.75
Wilwood's GT 72 Curved Vane Spec-37 rotors are manufactured from a proprietary iron alloy developed to withstand extreme temperatures with the highest possible degree of resistance against distortion, warping, cracking, and wear. The formulation for this alloy is a derivative of technology and materials that were significant in the development of the extreme duty military spec rotors that are manufactured by Wilwood. Every Spec 37 rotor is precision machined to less than .001" run-out, flatness, and parallelism. Combined with our proven GT Series asymmetrical face slot pattern and individual dynamic balancing, you are assured the smoothest braking available.
NOTE & CAUTIONS:
Spec-37 Heavy wall Castings
Left and Right 160-8398 160-8399
Wilwood Grand National III Calipers Pair
Wilwood’s GN lll is a time proven caliper that has been widely used with 5 on 5 hubs for stock car road course, and off-road competition. The 6.00" mount configuration (also available in 3.50" mount) incorporates this legacy of enduring performance, with options available for the latest brake system heat management technology.
The new generation GN lll uses the same popular 6.00" mounting pattern found on earlier GN caliper series. Te GN lll can be run with either a 1.25" or 1.38" thick rotor.
Wilwood Grand National III Calipers Pair with pads
ONE Pair 120-3030RS and 120-3031RS
Includes the new set of pads 150-9417K shown
Wilwood Dynapro 6 Piston Calipers, Lug Mount
Wilwood Dynalite Radial Mount Calipers USED PAIR
Billet Narrow Dynalite Radial Mount
Wilwood’s Billet Narrow Mount Dynalite (NDL) Radial Mount caliper series continues to grow in popularity over a wide range of racing and high performance applications. Starting at 2.70 pounds, this compact and lightweight proven performer is now available in a radial mount configuration. The Billet NDLR calipers can be directly mounted over studs, or used with a radial mount bracket kit in place of a tab mount caliper.
The Billet NDLR caliper is a compact, lightweight, and rugged caliper that provides strong clamping force from four 1.75" stainless cup pistons. The bodies are fully CNC machined from billet with internal fluid ports that eliminate external fluid tubes. Each caliper is equipped with four corner bleeds to accommodate mounting in all positions. The bridges are equipped with stainless steel anti-rattle wear plates. These plates reduce bridge wear and provide smooth, rattle free operation of the pads. A center bridge bolt adds overall caliper strength and positive retention of the top loaded pads.
Wilwood BRAKE PADS 150-9419K USED PAIR
Brake Pads
Street Performance / Racing Pads
Medium friction, highest effective temperarture range in medium temperature pad group.
Smooth engagement, torque curve increases in relation to temperature
Moderate wear rate at high temperature
Wilwood BRAKE PADS 150-9417K USED PAIR
Wilwood Brake Pads fits the Grand National III 150-9417k
Compound: BP-20
Performance Characteristics
Kids DJ Fire Suit
This is a DY Safety Fire Suit.
Kids size XL (15-16)
Single Layer Firs Suit
Worn 2 x, otherwise in NEW condition.
Color is red as pictured.
Over $175 new a great deal at this price!
This is a CLOSEOUT item.
Sold in as is condition.
Used Rubicon Steering Assembly
This is a factory USED RUBICON STEERING LINKAGE off a 2004 Jeep Rubicon.
Only used for a short time on the vehicle, otherwise in perfect condition.
JK Front OEM Coil Springs
These are JK OEM MOPAR Brand Coil Spring to fit any 2" diameter coil over shock (technically 2-1/2" diameter).
Should fit JK 2007-2010
Trademark Black color.
This item is discounted because they are out of the box and have some minor scratches in the powder coating
TJ EXT SC Gas Tank Skid Plate, #1
Do you have a GenRight EXT "SC" tank in your TJ, but the skid plate is bashed from the trail?
Here is your chance to pick up an almost perfect skid plate for cheap!
This item is discounted because the skid plate has some small scratches in the powder coating. So if you can live with that you can get a GREAT deal.
There is only 1 item left at this price!
All sales are final on closeout items.
No returns, exchanges or credits.
This item is being sold in "AS-IS" condition.
This skid plate fits the GenRight EXT SC gas tank only.
TJ EXT Gas Tank Skid Plate, #2
2004 TJ Stock Skid Plate
This is a OEM Skid Plate off a 2004 Jeep TJ.
Only used for a short time on the vehicle, otherwise it is in excellent condition.
JK OEM Rear Bumper
This is a Used Jeep JK OEM Rear Bumper
Removed from a JK 2007
Everything in the closeout section is sold in "as is" condition, no warranties (except on new items, from that manufacturer) implied or represented by GenRight.
JK Front Bumper Under Valance
This is a Used Jeep JK OEM Valance from under tha factory front bumper.
Removed from a JK 2007, but in perfect condition.
JK OEM Front Bumper Cover
This is a used Jeep JK OEM Front frame cover, behind the front bumper.
Removed from a JK 2007 and in perfect condition.
Limit Strap 15-1/2"
This is a Used DJ Safety Limit Strap
15-1/2" Long
TeraFlex FlexJoint, Weld-On
USED Jeep Motor Mounts
This is a pair of USED stock Jeep Motor Mounts.
This item is used.
USED Jeep TJ Motor Mounts
This is a pair of USED stock Jeep TJ Motor Mounts.
This item is used.
KING Bearing set MB7719AM 020
King 4.0L Engine Main bearing kit (020 OVER)
These are brand new still shrink wrapped as pictured.
KING Bearing set Rod Set CR648AM
King 4.0L Engine Rod bearing kit (010 over)
Hastings Piston Ring Set 667
Hasting Piston Ring Set 4.0L Engine 4.0L Engine Rod bearing kit (030 over)
These are brand new as pictured.
Used JK Air Box
This is a USED JK Air filter box in our closeout section
USED JK Gas filler bezel
This is a USED JK gas cap sleeve in our closeout section.
NEW SUMMIT Urethane Bushing Set
This is a NEW SUMMIT Machine Urethane bushing set with Zert fitting.
This super heavy duty bushing uses 5/8" diameter bolt, 2-3/8" diameter and 2-5/8" wide. It can be welded to anything you want (control arms, trac bars, etc.)
There is 1 available at this price!
USED JK Windsheild Washer Bottle, yellow cap
This is a USED JK WINDSHIELD WIPER BOTTLE YELLOW CAP.
This item is used, but in perfect working condition.
There is only one available at this price!
Used JK DR Side Rear Inner Fender
This is a Used stock JK Drivers Side Rear Inner Fender off a 2007 Rubicon.
Used JK Passenger Side Rear Inner Fender
This is a Used stock JK Passenger Side Rear Inner Fender off a 2007 Rubicon.
Used JK DR Side Front Inner Fender
This is a Used stock JK Drivers Side Front Inner Fender off a 2007 Rubicon.
Used JK Passenger Side Front Inner Fender
This is a Used stock JK Passenger Side Front Inner Fender off a 2007 Rubicon.
Only used for a short time, otherwise in perfect condition.
Used JK Passenger Side Front Flare Fender
This is a Used stock JK Passenger Side Front Flair Fender off a 2007 Rubicon.
Used JK Drivers Side Front Flare Fender
This is a Used stock JK Drivers Side Front Flair Fender off a 2007 Rubicon.
Used JK Passenger Side Rear Flare Fender
This is a Used stock JK Passenger Side Rear Flair Fender off a 2007 Rubicon.
Used JK Drivers Side Rear Flare Fender
This is a Used stock JK Drivers Side Rear Flair Fender off a 2007 Rubicon.
JK OEM Front Bumper Assembly
This is a Used Jeep JK OEM Front Bumper Assembly NO LIGHTS
JK OEM SWAY BAR, Rear
This is a used Jeep JK OEM rear SWAY BAR
Removed from a JK 2007 and in perfect working condition.
JK 3rd Brake LIGHT and TIRE MOUNT
This is a Used Jeep JK 3rd brake light with spare tire mount.
JK OEM TAIL LIGHT
This is a Used Jeep JK OEM Tail Light
Stock Rear TJ Plastic Fenders
These are the rear OEM fenders from a Jeep TJ. They are a great replacement for a broken set. Comes as a pair.
Factory Track Bar
Factory Trac Bar.
This is the closeout grab bag, you have to figure out what it fits from the picture.
Factory Trac Bar.
Factory TJ Front Sway Bar Cover
Factory TJ front sway bar cover.
Factory YJ clutch fan
Factory YJ Clutch fan off the 4.2 L 6 cylinder.
Starter 4.0 L 98-91 Jeep Models
Starter 4.0 L 98-91 Jeep Models.
Jaz 1 Quart Overflow Bottle
Jaz 1 Quart Overflow bottle.
In perfect condition, used once and removed.
Factory TJ Gas Filler
Factory TJ/LJ Gas Filler and cap.
OEM JK Parts
This is a full stock set of a Jeep JK Bumper, Valance, Fenders, Rear Fenders...
Beard Limit Strap - 12", Pair
12" Quad Wrap Beard Limit Strap. Sold as a pair.
Were used for product display and are dusty, otherwise new.
Beard Limit Strap - 20", Pair
20" Quad Wrap Beard Limit Strap. Sold as a pair.
Beard Limit Strap - 22", Pair
22" Beard Limit Strap. Sold as a pair.
DJ Safety Limit Strap - 16", Pair
16" Quad Wrap DJ Saftey Limit Strap. Sold as a pair.
Single Beard Limit Strap - 20"
20" Quad Wrap Beard Limit Strap. Sold individually.
12" Single Beard Limit Strap.
Beard Limit Strap - 14"
14" Quad Wrap Beard Limit Strap. Sold individually.
TJ Stock Front and Rear Fenders and Rockers
This is a used set of white stock Jeep TJ front and rear fender flares with the rocker covers.
Includes everything pictured.
Factory Jeep TJ E-Brake Cables
This item is a pair of Emergency Brake cables off of a Jeep TJ.
Jeep TJ Factory Roll Cage Pads
This is a set of used foam from the stock roll cage on a Jeep Wrangler TJ. The foam inserts are as pictured, but will hold together when the factory rollcage cover is put over them.
High Performance Regular Duty Transmission Cooler
This is one of the two coolers that comeswith the U-Haul transmission cooler (PART# 13236)
All high-performance automatic transmission coolers fitboth domestic and import vehicles with automatic transmission. Stacked plateconstruction and brazed aluminum technology provide maximum strength, coolingefficiency and oil rate flow.
Ring And Pinion For Dana 44 Limit Slip 3.55
This is a ring and pinion gear set for a Dana 44 axle with a limit slip and a 3.55 gear ratio. This is a great way to gear up for cheap and get more out of your Jeep.
Tow Bar Mounts
This is a pair of tow bar mounts that will bolt on to let your Jeep be easily towed. This listing is for the two pictured mounts only.
Spicer JK Rubicon Front Ring And Pinion For Dana 44 4.10
This is a ring and pinion set for a Dana 44 FRONT axle on a Jeep Rubicon JK. The gear ratio is set at 4.10.
For Rubicon JK FRONT
Made for Dana 44
4.10 Gear Ratio
Part# 44-4.10-4RC
Alt# 2005025
NOTE: This closeout item comes in a different manufactures box.
Spicer JK Rubicon Rear Ring And Pinion For Dana 44 4.10
This is a ring and pinion set for a Dana 44 REAR axle on a Jeep Rubicon JK. The gear ratio is set at 4.10.
For Rubicon JK REAR
Made for Dana 44
4.10 Gear Ratio
7/16" Threading
Part# 44-4.10-4
Alt# 2005117
Used Jeep TJ Air Box
This is a USED TJ Air filter box in our closeout section.
New TJ Dana 44 Rear Oil Seal
A brand new, in the original packaging rear Dana 44 oil seal for a non-Rubicon TJ.
TJ Stock Coil Springs Front And Rear
A full set of Jeep TJ front and rear stock coil springs. This is off an OEM Jeep TJ.
Stock Jeep Jack with tools
This is a stock Jeep lift jack with tools. A great replacement for non lifted Jeeps.
Factory TJ Roll Bar Tubes To Windshield
Jeep TJ Roll Bar extensions off of stock Jeep roll cage to the windshield.
Jeep Factory Inner Fender Well Rubber
This is a pair of the inner fender rubber backing that prevents mud and dirt from entering the engine compartment. Replace your torn or damaged inner fender rubber and keep debris away from your engine.
Jeep TJ Stock Rear Fender Flare Silver
These are the rear OEM fenders from a Jeep TJ. They are a great replacement for a broken set. Comes as a pair in silver.
OEM Slip Yolk Eliminator
Factory slip yoke eliminator for a Jeep TJ. This design is not conducive to off road use nor the steeper operating angles caused by suspension lifts.
Jeep TJ Transmission to Belly Pan mount
This is a stock belly pan for a Jeep TJ.
TeraFlex Automatic Transmission Seal Extension
A simple extension is used to position the seal of the automatic transmission pr properly against the transfer case. This kit may be required as needed. For YJ and TJ 3-speed automatics.
Stock Jeep TJ Rear Coil Spring Isolators Pair
Stock rear coil spring isolators, pair. Replace the worn out rubber pads on the rear of your Jeep with these stock used replacements for cheap.
Stock Jeep TJ Front Coil Spring Isolators Pair
Stock front coil spring isolators, pair. Replace the worn out rubber pads on the front of your Jeep with these stock used replacements for cheap.
USED Jeep TJ Gas Filler Bezel
Mopar Crush Sleeve
This is a Mopar Crush Sleeve. Part # 84860E, 46069.
TJ 1" Puck Spacer Lift
A pair of 1" puck lift spacers for Jeep TJ, with a 2" inner diameter.
Leaf Spring Center Pin
A single leaf spring center pin. This is the pin that holds the leaf spring suspension in place to the mount.
Synergy 10" limit Strap, single
10" Synergy Limit Strap. Sold as a single strap.
Crown Steering Damper Stabilizer
This is a Crown Steering Damper Stabilizer that will fit a Jeep TJ or LJ.
Part #'s
52088959AA
52087827
Used TJ motor mount
This is a pair of USED stock Jeep TJ Motor Mount. Sold Single.
AEV Hood for TJ/LJ
This is a practically new AEV hood that has never been mounted. It was bought new but never used, just a little dusty.
Yes, this hood can be used with the GenRight Hi-Fenders.
AEV's TJ Highline Hood adds a splash of style to your TJ Wrangler while also raising your hood line to accommodate larger tires with less suspension lift. Designed to work as part of our Highline Body Kit, some customers also use this hood with aftermarket or custom fabbed tube fenders.
TJ Tube door cover with pockets
This item is a new and unused Bestop tube door cover with pockets.
Dana 30 Differential Cover
This is a single Dana 30 differential cover. These are used and slightly rusted, but are still usable with a light brushing and some maintenance.
D30 Differential cover
Pair of OEM TJ Headlights
A pair of stock Jeep TJ head lamps, great as spares or replacements.
2007 JK Automatic Transmission, low miles
This is the automatic transmission from a 2007 Jeep JK Rubicon. It has only 50,000 original miles and was taken off of one of our Jeep Builds.
Transmission: 42RLE - Automatic Four Speed w/ Overdrive
Availability
Optional
Description
Electronic governor, electronically controlled converter clutch
Gear Ratios
Teraflex 9550 TJ shocks
This is a set of 4 Terra Flex 9550 shocks. Inculdes 2 front and 2 rear shocks. For 97-06 TJ/LJ.
97-02 TJ rear bench
This the rear seat out of a Jeep TJ 97-06, kept in new condition with buckles. Folds down.
This is a take out in excellent condition.
Factory JK Fog Lights
Factory JK Fog Lights.
JK side marker lamps
JK Amber Fender Reflectors.
Single King 2.0 Air Shock
This is a SINGLE 2.0" x 16" travel King Air Shock.
Kevko Racing Oil Pan
Kevko Racing Oil Pan. Brand new, wrapped in the box.
For 5.7 Hemi engine.
Yukon Gear Replacement Ring & Pinion For Dana 60 Reverse In 4.88
Yukon Ring & Pinion sets give you the confidence of knowing you're running gears designed for the harshest of conditions. Whether it's on the street, off-road, or at the track; Yukon ring & pinion sets deliver unrivaled performance & quality. Yukon uses the latest designs and manufacturing technologies to provide a quiet running gear that is strong and easy to set up. All Yukon ring & pinion sets come standard with a one-year warranty.
Yukon Gear Replacement Ring & Pinion For Dana 60 In 4.88
Compatible with Differentials:
Dana 60 Front, Disconnect Design, '00 & newer
Dana 60 Front, Disconnect Design, '98 & older
Dana 60 Front, Disconnect Design, '99 only
Dana 60 Front, Standard Rotation - 16 Spline
Dana 60 Front, Standard Rotation - 30 Spline
Dana 60 Front, Standard Rotation - 35 Spline
Dana 60 Quadrasteer Rear
Dana 60 Rear - 16 Spline
Dana 60 Rear - 23 Spline
Dana 60 Rear - 30 Spline
Dana 60 Rear - 32 Spline
Dana 60 Rear - 33 Spline
Dana 60 Rear - 35 Spline
Yukon Gear Replacement Ring & Pinion For Dana 60 Reverse In 5.13
Dana 60 Front, Reverse Rotation
Yukon Gear Replacement Ring & Pinion For Dana 60 Reverse In 5.38
Yukon Gear Yoke Ford 9" 35 Spline
Yukon yoke for Ford 9" with 35 spline pinion and a 1350 U/joint size, made from 4140 steel. 3.625" snap ring span, 1.188" cap diameter. Outside snap ring. All Yukon yokes come with a one year warranty against manufacturing defects.
Ford 9" (9 inch) - 28 Spline
Ford 9" (9 inch) - 31 Spline
Ford 9" (9 inch) - 35 Spline
Yukon Gear Overhaul Kit For Dana 60 Front
Yukon Master Overhaul kits give you all the high quality parts you need to start & finish every differential job. Yukon offers more tailor-made kits than any other manufacturer in the industry to meet your specific installation needs. This kit uses Timken bearings and races along with high quality seals and small parts. Included in this kit are carrier bearings and races, pinion bearings and races, pinion seal, complete shim kit, ring gear bolts, pinion nut, crush sleeve (if applicable), oil baffles and slingers (if applicable), Thread locking compound, marking compound with brush, and gasket. Yukon's Master Overhaul kits are the most comprehensive and complete kits on the market. They do extensive research to ensure that every kit is specially tailored to your application.
Yukon Gear Competition Zip Locker For Dana 60 4.10 And Down
The Yukon Zip Locker is the latest in on-demand traction. Its air-operated design allows you to switch from an open differential to 100% lockup when you need it, giving you the ultimate in driver select-ability. This is a competition only unit that defaults to lock if air pressure is interrupted. The Yukon Zip locker is an air operated locker that provides select-able traction for off road or street use. This unit features 4320 Chrome Moly internals for added strength. Assembled in the USA! compressor sold separately. All Zip Lockers are backed by the best warranty in the business! Yukon covers the replacement unit and covers any collaterally damaged parts and associated labor, up to $2,000! This is a narrow case locker. If you have a wide housing, please order two DS 42563 with your locker. This locker is ABS compatible.
Dana "Super" 60 - 35 Spline
Dana 61 Front - 35 Spline
Dana 61 Rear - 30 Spline
Dana 61 Rear - 35 Spline
Pilot 8" review mirror
These rear view mirrors provide a full, panoramic view to make lane changing easier. Pilot Motorsports provides an affordable option for a number of automotive accessories.
Rampage Products Trail Lite Super Bright LED
Rampage Products LED universal light kit attaches on to any square or round bars up to 4in using wraparound hook and loop fasteners. Comes with long life superbright led bulbs. The light uses a quick release for easy removal and mobility. Uses three AAA batteries which are not included.
Just added some more items in the close-out section!
Factory LJ D30 front axle with steering damper
Factory LJ 05' Dana 30 Front Axle. Was in perfect working order when removed, and is a 'take-off' from a recent Jeep LJ build GenRight completed. Complete with brakes and steering, and a steering dampener installed on the front.
Smashed your axle or stripped it out? You won't find a better replacement or spare at this price!
Front LJ Dana 44 rear axle with arms
Came off of a new GenRight build and in perfect working order.
Comes with break cables. Upgrade your rear axle to something beefier or get a spare for your hard core rock crawling rig! This axle is priced to move so pick it up while you can!
Factory Gas Tank, Cherokee '98-'01
This is a Used factory gas tank for a Jeep Cherokee XJ 98'-01'.
Part #: 52100179AD
1998 to 2001 XJ CherokeeFactory style replacement part.
New Process Transfer Case NV 231J, Used with Slip Yoke Eliminator
This is a New Process or New Venture Gear Transfer Case NV231J that came out of a 4.0L 98 TJ. It also comes with a slip yoke eliminator. It is a 2 speed transfer case with a low range ratio of 2.72:1 with a locked differential.
Alternate Part #: 26338
New Venture Gear 04/01/98 AM 03-40-38 Pints #105 211
This is a New Process or New Venture Gear Transfer Case NV231J that came out of a 4.0L 05 LJ. It also comes with a slip yoke eliminator. It is a 2 speed transfer case with a low range ratio of 2.72:1 with a locked differential.
Alternate Part #: 45773
Used winch cable with hook
This is a USED winch cable from Warn. Great as a back up winch line! Includes hook.
Estimated to be: 3/8" x 125'
Warn winch cable with hook
Jeep Wrangler TJ solid bench rear seat 97-02, used
This is a used rear seat out of a Jeep TJ 97-06. Folds down, no buckles.
Aluminum Fairlead, old GenRight Logo
This is a Used GenRight Aluminum Winch Fairlead with the old GenRight logo to be used with synthetic winch lines, just like we use on all the GenRight Jeeps.
FEATURES
· Made from 3/4" thick Aluminum alloy
· CNC Machined
· Recessed (flush with front surface) Stainless mounting bolts
· Engraved GenRight Logo above opening
· Large machined radius to keep synthetic winch ropes alive
· Attractive & weather resistant Black anodized finish
· Easy to install (nylon rope is optional upgrade)
· Limited lifetime warranty
· Made in the USA!
Notes:
For use with synthetic winch ropes only!
Size: 12" long x 3" wide x 3/4" thick
