70worm New member Nov 12, 2012 #1 Is it the same as other V8's, take off distributor, get tool and use drill?
F flatie46 New member Nov 12, 2012 #2 Pretty much, I used a wood drill bit with the tip ground off. Pull a valve cover and turn it till you see it come out at the rockers.
Y2KTJ New member Dec 10, 2012 #3 I used a big old flat blade screw driver cut off the handle and locked it in a drill, always worked great for me.
