Snitty
As I posted a few days back... I have been intending to install some add-a-leafs to my packs.... I bought a couple chevy 1/2 ton spring packs and pulled them apart, sanded them, matched strengths, and cut to various lengths. I installed the new leafs in the rear today, I plan on installing the front tomorrow. I am VERY happy with the suspension now. I used to sag way below stock and could never carry passengers in the back seat... This install gave me 2" over stock. for $30 i would say this is a GREAT deal. BUT... I have a few drawbacks.
When driving home, I found that I had a BAD vibration at 55 mph as well as when I idle down in 3rd gear. AND... even worse... when i start hard in first gear.. I have some popping noises. At first I thought it was something not tightened down all the way, or it could have been Ujoints... When I start in first with high rpm (which for me is 1500 to 2000) I get something between a clang and a pop. A few times it would pulse as if it were something binding in the drivetrain.
I had a friend drive it while i looked under it... I couldn't find anything going wrong... If I could have found something, it wouldn't bother me... but I got nothing. I am hoping I don't have a damaged differential... I doubt it is... but i'm gonna look incase. I am going to install a 1" shackle lift to turn my pinion up and possibly drop the Tcase 1/2" to get the driveshaft a little better in line. I know 2 inches is not much of a lift... but i've had problems with my drivetrain before.. I want to eliminate anything that could cause vibration.
So, because its a jeep, and its doing they all do, i'm accepting the flaws so far and I'm very happy with my inexpensive repair/lift. I'll keep you guys posted on how it works out. [addsig]
