jeep blower not working
99jeeptjguy
hi not sure how to post but i am tryin I just bought a 99 tj and have no air blowing on any speed from reading i assume its the fan switch my question is how do i get at it and is it a hard re and re? thx
have you checked the fuses i would say its the fan resistor but you said no speed was working if it was the resistor only high would work
Did the fan motor ever work since you owned it? Previous post to check fuse and resistor is a good suggestion. But the motor itself could be bad too as was on mine. In my case the motor would buzz a while before going on or off. Eventually needed to be replaced.
