Leak in Cab
WarthogExplorer
Everytime it rains hard for a lengthy period of time I end up with water on the floorboard of my driver's side. There are no signs that the water is running down the inside of any of the windows and I can't seem to discover where the water is leaking from. Any ideas?
I had this problem and I had lost a grommet (sp?) to a hole in my firewall.
RE: Career Change 2: Radiologic Technology
When it happened to my 04 TJ (I'm not sure what you have) it was a rubber piece missing. I have full doors and there is a plastic surround that goes around them. At the bottom of the surround there is a metal pin that goes into a rubber piece that is attached to the tub. Mine were missing.
Welcome to Jeepz.com, what year and model Jeep do you have?
It's pretty common to have a poor seal at the base of the windshield, allowing water to come in. You can have somebody run a hose over the outside while you inspect for leaks.
RE: 258 Upgrade
I also know (thanks to the guys here) that the drain hose from the hood vent can get plugged with debris and cause water to overflow into your rig.
