lift kit question
yelrubi16
anyone installed a 3.5 superflex rubicon express kit on a 04 rubicon
if so do you need to include the installation of a slip yoke eliminator and CV driveshaft on the stock NP231 transfer case is recommended. The installation of a CV yoke and CV driveshaft on the stock Rubicon NP241 transfer case is recommended. Upper adjustable rear control arms are required for CV driveshaft use.
so far it is stock 6cly with 4 speed auto
http://www.rubiconexpress.com/dynamic/mainpage.asp?folderid=184
is this a good price for the kit and it installed with doestech shocks for $1,100 or $1,400 don remeber wich
thanks in advance
You don't need the SYE on the Rubi, and I'm not familiar with the Rubi rear driveshaft but if it's already the double-cardan (CV) type you'll be fine there too. not quite sure I understood your post completely.
Rubi's have SYE factory! Not sure about a 3.5 lift, but with the 5.5 long arm on a rubi, you need to take the rear drive shaft off and install a intermeadiate shaft to lengthen it.
