are you doing a doubler?
the case is probably sronger than anything jeep ever came from the factory with, and has the weight to prove it. The 3-1 kit is a little bit of a PITA to install, but fairly straight foward. I would recommend a 203/205 set up first. it's a little cheaper, and way easier. plus you can upgrade to the 3-1 later
