misc. jeep stuff need room
tow_hook
1993 4.0 country xj pcm 30$
pre 97 xj fuel pump for a steel tank 30$
2 set of lift blocks 1 set is alum 2" tall for a 2.5" spring 30$. the other set is steel and is 3" tall for a 2.5" spring 30$
yj axle mounted bump stops i have 3 sets 20$ a set new they run 45-50$ a set
1998 xj 4.0 motor runs great, still in the jeep, you can see/feel it run. the local yards are asking 500-1250$
500$ takes it.
xj control arm drop brakets by r.e. with braces that mount to the cross member 225$
93" or older p/s pump w/ res 25$
96" xj double diaphram booster / with master, a must have upgrade for 95" and older xj's. it's the old year bolt in double booster 50$
2 yj / xj head lights 10$
95" red yj fenders 100$
u-haul universal 4 pin flat wire harness 10$
xj hood release cable good on all year xjs 15$ new ones are 40$
yj steering linkage 30$
99-01 wj p/s pump fits 4.0 an 4.7 it's a new fenco pump and res.
wj limited front floor mats black 30$
wj limited rear floor mats black 30$
psc alum heat sink new 100$ 50 takes it
ipf back up light 50$ takes it
84-01 xj rear tow hook 25$
