I have an oil leak and was looking for some opinions. I have a 78CJ7 with the 304. Well recently I took off the factory air cleaner assembly and replaced it with the crome K&N style air cleaner. Well that is when my problem started. After driving oil is pooling up on the water pump just below the intake manifold. I can see what looks like splattered oil on some of the hoses in that area. Now when the jeep is just sitting there and running I can't see any leaking but when I drive it and stop there it is. One thing I did is the tube where the oil goes that runs down throught the intake and into the motor had an opening where a tube went from it to the old air cleaner. I just plugged it but later found out that I should remove the plug. Well now I am wondering if when driving if oil is now coming out of that opening. I put the old cleaner back on tonight and am going to give it a test drive in the morning. So I was curious if anyone had any thoughts on this.
Thanks
Thanks
