smalloy24 New member Dec 6, 2010 #1 Every time I back up have problum with it piping out of gear any ideals anyone
Bounty__Hunter Super Moderator Dec 7, 2010 #3 Do you have the 4.2L 6cyl engine? If so my '88 with the same Peugeot BA10/5 transmission did the same thing. It did fine if I held it in reverse. I think the only fix is a rebuild or replacement of the transmission.
T Tony Fuzi New member Dec 7, 2010 #4 If you have put a body lift on it check to see if the shifter is hitting the floor .
smalloy24 New member Dec 7, 2010 #5 Yes has a 4 in body lift if I slam it in reverse it wont pop out I need to look and see if it is hiting and thanks everone
superj Active member Dec 7, 2010 #6 4" body lift???? wow man, you sure that is safe? it seems like any kind of sudden stop and the bolts are shearing off
smalloy24 New member Dec 7, 2010 #9 Yea I had to cut some of the metal so it would go all the way in gear works great now
