Starter change
Which eng? automatic or manual?
why did you change starter?
Maybe the starter was not the issue.
burn out - ?
when you turn key - any clicking - dash lights -
Anyway this diagram will make it easy - unless you have a remote starter.
  • liberty automatic.pdf
this may be easier to understand
  • starting-charging-starting-circuit-a-t-1-of-1.pdf
the second diagram is easier -
fuses good?
does relay click when key moved to start?
Try moving shifter - N - to start.
Remote starter yes or no ?
CEL is light on?
A test light and diagram auto repair 101.
Make sure your battery connections are clean and tight. A loose connection will let your lights and radio play but won't pass enough current to crank the starter.
A simple check is to short the solenoid control wire to the power wire. It bypasses the ignition circuit, if your starter is good it will crank.
