anyone know what the stock axle is on a 04 wrangler with a 4 banger? and if i can put a Dana 44 Rear Axle 3:73 with posi in without changin things around? or what would i have to do to make this work?
It's a d35 rear axle, 3.73 gears if you have the auto and 4.11 if you have the 5spd. Check the axle tag bolted to the diff cover to be sure of the ratio. You can swap in a TJ d44 if the gears match, otherwise you have to regear to match.
