signguy
Hope I can find a little help sorting out a 1979 CJ 5 258 I6 that I just bought. First, the carb does not appear to be the one that should be on this rig. It is the Carter BDL but it has a bunch of wires and vacuum tubes that don't connect to any thing at all. It also has the little white plug in gizmo, (computer plug in) on the rear of the carb. Would like part numbers for what should be on here. Runs really rough. Cleaned out idle jets and tubes. Still dribbles gas into the venturies. Old beat up Holley came with the deal. Should I kit it and replace the Carter. Also, timing appears to be 180 degrees out. Is that possible?
