OK, with the '04 SE you sit in the same position I have been since '03. Mine was a DD......I have a company truck now so it doesn't get driven daily ('03 with 117,000 miles - it has been driven ALOT!!). It's quite a capable vehicle as is.........trust me. 31's will give you a bit more ground clearance than stock - 1" to 1 1/2" more. The motor, gears, and stock axles will handle it just fine. Now to go further..............33's or 35's or such.......requires some more thought. Will the Dana 35 handle the stress? Will the 4.11's handle the extra rolling weight/diameter? Will the stock suspension cause rubbing/flex issues? Personally, the next mod I was considering was a locker/lockers. But then, if I'm putting in a locker/lockers, why not re-gear while I'm at it??? And if I'm going to re-gear, why not lift it and go with bigger tires??? I think you see where I'm going....................isn't it great owning a Jeep!!!!:lol: :lol: :lol: :lol: I'm sure you've heard it, but the name "Jeep" equates to Just Empty Every Pocket!!!!:lol: :lol: :lol:
I'm still thinking a locker as my next step. From what I've been through with the Jeep, it'd be my best bang for the buck.
BountyHunter and Currupt (and others I'm sure......don't mean any dis') both run 4bangers a WHOLE lot harder than I do. I'm sure someone else will chime in with better/added advice. ENJOY!!!!
