1. CJ headlight wiring colors
    Does anyone know the headlight wiring colors for a cj. The high beams, low beams, and ground.
    Thanks
    Nov 2005
    Albany~town, Oregon
    1,348
    Re: CJ headlight wiring colors
    Red with tracer is Dimmer switch feed
    Gray with tracer is High Beam Indicator
    and Gray (solid) goes into headlight circuit
    Black is normally ground
    This is out of a '78 Jeep service manual wiring diagram, hope this helps
    Quick fixes are so named for how long they stay fixed.
    If you run out of gas, no matter which way you decide to push, the closest gas station will always be uphill and in the other direction. Corollary: The likelihood of running out increases when all of the nearby gas stations are closed.
    The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep.
    We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch).
    Try this diagram as well.
    Attached Thumbnails Attached Thumbnails CJ headlight wiring colors-cj-wiring-diagram-1979.jpg
  1. automatic headlight wiring
    By Saleen4971 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-19-2004, 11:32 PM
  2. Colors
    By flip124 in forum Wrangler and CJ
    Last Post: 11-11-2003, 11:32 PM
  3. Fly your colors!
    By dingus in forum General Chat
  4. Original 72 CJ5 Colors
    By Tug-n-pull in forum Wrangler and CJ
  5. 1993 YJ Sahara colors
    By far_right in forum Wrangler and CJ
