I just put a 1 1/2 in lift in my YJ and now I have the shake
Wranglerit
I put new leaves in an added a leaf to them so now I have 5 in fromt and 6 in the rear, the ride is great.......I noticed a vibration and knew I would have to take and have the front aligned but noticed my transfer case leaking the yoke is about an 1 1/2 out . Does this mean I need to get a longer driveshaft ...???? and what else should be replaced to prevent any firther problems ???[addsig]
1060031
instead of just getting a longer shaft... get a CV shaft... this will eliminate driveline vibrations no matter what angle your shaft is at... its a much better way to go... I just did a AAL lift to my jeep... I am pricing shafts this week[addsig]
1060043
i feel dumb for asking this b/c i should know..... but.... this is what this board is for.... but do i need new drive shafts for a 2.5" susp lift??[addsig]
1060070
no sir, you shouldn't need one... but then again... you can't lose with a CV
[addsig]
