    Parking brake cables for lifted YJ, how?
    We have a 94 YJ Wrangler Sahara with 3.5 inch spring lift plus 1/2 inch lift from 1 inch extended boomerang shackles. So, 4 inches total.
    I need advice on how to handle the rear parking brake cables. I've searched for extended cables and relocation brackets.
    A solution would be greatly appreciated.
    We will have a similar issue for the ABS sensor cables. Any thoughts on whether we should cut and splice them versus fabricating a hangar to drop them.
    This is my first post. If it is smarter to separate the e cable question and the ABS question into two posts please let me know.
    Thank you,
    TE94YJ
    Dec 2010
    California
    470
    Re: Parking brake cables for lifted YJ, how?
    The maker of your lift should either sell or have referrals to extended parking brake and extended ABS cables. I suggest checking their web site or giving them a call.
    My Rubicon Long Arm kit came with everything I needed fir the parking brake. My Jeep is pre-ABS so I did not have that hurdle to cross.
    Thanks for your response Jeepergeo. I'm helping out my son with this project and unfortunately he did not start with a kit if that is what you meant by the "maker of the lift". I have referred to the websites and installation pdfs of kit makers for clues but have yet to pick up the phone. Surely my son knows the spring maker. I will start there.
  1. Replies: 1
    Last Post: 02-22-2017, 01:56 PM
  2. How adjust parking brake (hand brake; ebrake)
    By PanchoJeep in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 06-02-2011, 02:08 PM
  3. Parking brake cables
    By Snitty in forum Wrangler and CJ
    Last Post: 02-27-2011, 06:04 PM
  4. E Brake cables to a D44
    By Joopin in forum Wrangler and CJ
    Last Post: 09-09-2003, 02:49 PM
Tags for this Thread
