1. 2000 Grand Cherokee Oil Leak
    I have a 2000 Grand Cherokee Limited with a V8 4.7L that is leaking oil out of the front part of the motor. Looks like its leaking right out of the oil filter area, but its not because of the oil filter. Any suggestions? Is there a plug or something in the front of the motor that I should check?
    Re: 2000 Grand Cherokee Oil Leak
    The power steering pump is on top of the oil filter, have you checked to see if its the power steering pump or line is the source of the oil leak?
    I know its an oil leak because its using oil. But the power steering pump is also leaking. Could the lines be bad?
    Quote Originally Posted by cundifc View Post
    Possibly, however, i would de-grease the area first and re-check the area where it's leaking to isolate the source.
  1. Grand Cherokee Limited 2000
    By bharrell in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 10-03-2009, 01:41 AM
  2. Replies: 12
    Last Post: 06-16-2009, 08:26 PM
  3. Grand Cherokee WJ 2000
    By petemilner@aol.com in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-11-2008, 11:21 AM
  4. 2000 aftermarket Grand Cherokee wheels
    By DrBoost in forum Items for Sale, Trade, or Give Away
    Last Post: 07-17-2006, 09:48 PM
  5. ques about 2000 Grand Cherokee
    By 88WRANGRED in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-09-2004, 07:03 PM
Tags for this Thread
