Thread: reverse lights?
    NCjeeper's Avatar
    NCjeeper is offline Senior Member
    Jan 2006
    125
    reverse lights?
    my reverse lights failed along with cruise control. the cruise light would illuminate in the dash when i pressed the button, but wouldnt set. i checked my fuses, replaced the only one i saw had blown, but reverse lights still do not work. what could it be?
    dingus's Avatar
    dingus is offline Senior Member
    Aug 2002
    PA USA
    2,292
    Re: reverse lights?
    auto transmission? popular malfunction is the "NSS" (neutral safety switch). read about it online, have to remove it, crack it open, clean the connections and put it back together basically. if you need a manual, email me.
    NCjeeper's Avatar
    Jan 2006
    125
    Re: reverse lights?
    yeah it's an auto. i guess i'll give it a shot? thanks for the manual
