Just picked up the newest issue of JP and was reading through it. There is an article ("Coil Suspension Sundries") that is basically a bunch of tips for upgrading coil suspension systems (i.e. TJ's or JK's (or I guess YJ/CJ's that have been converted would also apply)).
In the article it says you should run swaybars off road with quad-coil suspensions. It says "Don't assume massive flex means massive performance. When you run coil springs, sway bars are your friend. ... We know a lot of enthusiasts like swaybar disconnect systems for jaw-dropping flex, but running no swaybars on a quad-coil suspension is a recipe for instability and a possible rollover."
I've never heard this before. As a matter of fact, I've always heard just the opposite - that disconnecting the front swaybar off-road only helps performance. This article isn't going to keep me from installing my JKS Quicker disconnects, but I'm just wondering if anybody agrees with the article?
