None, unless they are worn. If you're rebuilding, you want to replace them. If you're rebuilding the heads, replace them. If your engine is old, replace the camshaft as they wear quite a bit. You'd be surprised what a new stock cam can do to an old engine.
Sometimes a higher ratio rocker is available for more valve lift, and even roller rockers for better performance.
What's your plans on getting inside the engine?
