Body lift and MM lift
TJoffroadr
So this past Sunday I installed my 1.25" body lift and the 1" MML, they went smooth. Body lift went on in about 30 minutes, MML took a bit longer, hard to get to bolts are crappy. Anywho..... Now that it's on and I've been driving it around, when I turn it sounds like something is knocking on the frame. I can feel it under my feet. I checked everything, bolts are still tight and nothing has moved. I don't know what it could be.
Transfer case linkage could be in a bind. Did you adjust the linkage mechanism after the modifications?
A body lift and MML both change the distance between the transfer case and body. The transfer case linkage is connected to both so it's easily screwed up.
That's gonna be my next check.
