Even with as many as we put on in our shop I would never put a yok nut on with an impact gun when tightening against a crush sleeve. If you over tighten it you ruin the crush sleeve and possible the bearings. It's not worth it. The crush sleeve will be adjusting your back lash on pinion on those. Tighten it back down with a rachet, tighten it down until it snugs up then give it an extra turn to lock the nut into place, or use an inch pound wrench and tighten to 5 inch pounds more then previous as mentioned above.
