Mine is an 85 cj7 with the 258-6cyl. The new cover is nice, but the holes are not lining up right. My stock plastic cover was broken at the back. In the instructions for the new one they say you have to drill out the two blind holes on the drivers side of the head (that are unthreaded and sit under the original valve cover) and thread them 5/16x 18. Thats fine, but I drilled the front one too deep and went into the water jacket. That's easy enough to fix (although highly dissapointing). But the stock retainers that thread down onto the head bolts and hold the valve cover down, do not touch my new cover. So now if I plug the hole I screwed up, there is nothing on that area of the cover to hold it down right. I thought of making a 5/16 stud and plugging the hole, then having it go to 1/4 on top and just putting a nut on it to hold the valve cover down. This wont work either cause the clearance is so tight that a nut wont start on the threads of the stud and be able to be tightened by anything.
