TB stands for throttle body. This is what controls how much air enters your engine. As you press the gas pedal, the throttle opens, letting more air in, and then your computer adds more fuel to kep the mix right. If you bore out your throttle body, you are allowing more air to enter your engine, therefore, more fuel, therefore, more power! A throttle body spacer is another cheap mod that many will tell you is worthless. You mount this between your throttle body and intake manifold, so you are increasing the space between the two. I could be worng on this, but I think this creates a larger vacuum effect so your engine can suck in more air. Some spacers have channels cut in them that gives the air coming in a spin, creating better fuel atomization, meaning the gas is better mixed with the air, therefore more power! I don't think throttle body spacers do much good. I have never used one, but many have told me that they are not worth the money.
