Question about my turn signals
cj_brian
Hi,
I have a cj 5 with no turn signals.The jeep previously had an underhood fire and the wiring was fried.The guy i bought it from rewired it, but when he did he only wired the headlights and brake lights, it has no turn signals or backup lights. I need these lights to pass inspection and have no idea
how to go about getting them to work
Thanks
If you are going to wire them yourself you will need to find the wire from the multifunction switch.Run wire from switch to blinker.It would not be to hard if you get a wire diagram for the multifunction switch.
In 1973 the turn signals were wired from a switch mounted on the outside of the steering column. Aftermarket switch & wiring harnesses are available...check the venders forum. I have a used one that works that I can sell you CHEAP. PM me if you're interested.
