Recently the fuel pump died on my 2005 Jeep Wrangler. The Jeep would crank and crank without starting, and I found that by adding a small amount of starting fluid directly in the intake, it would start and run for 3 or 4 seconds.
So, with a diagnosis, I went on Amazon and purchased this Mopar fuel pump assembly. The pump itself is metal, and sits inside of a plastic housing. This plastic housing also holds the float (which is responsible for telling how much gas is in your tank). You could get away with only changing the pump itself, but I had read that the plastic could be old and brittle (you never know until you remove it) - in my case the plastic housing would fine, and could have been reused. Having said that, it does not appear that Mopar sells just the pump, but instead sells the entire assembly, and this isn't a job I'd want to do twice.
The process is straight forward - you remove the fuel tank, and replace the pump, then re-install the full tank. In practice, things are never that easy, however in this case, about 3 hours with of wrenching should get the job done.
For reference, here is what the entire fuel pump assembly looks like for a 2005 Wrangler
![cacheJeepzImage.php](https://www.jeepz.com/forum/cacheJeepzImage.php?img=https%3A%2F%2Fwww.ucguru.com%2Ftest%2Fwrangler%2Fwrangler-fuel-pump.jpg)
