my jeep ran completly out of oil. the presure guage was pegged out and thenwent to zero, i checked the oil and nothing was there. what would cause this. Thanks,
Tink
Junky jumped in on that one. you can have nothing on the dipstick and still have plenty of oil in the engine. If you ran out completely you'd be buying a new motor. You're likely burning oil and, as 'pile said, its going out the tailpipe
Might want to check your oil pressure sending unit, also. When that little diaphragm goes, your needle will do as described and it'll spew ungodly amounts of oil.......you can actually see the trail behind you.
Had a hunch when you mentioned that. Mudwoman's went out on her YJ a short while back (after similar guage readings).......left a huge puddle in the WalMart parking lot........took 4 quarts to get 'er home (10 miles + or -). Easy, relatively cheap fix!!! Glad all is well again, Tink.
