glenn beck
im repairing my friends jeep and the last problem i have to fix is the clutch. the clutch has at some point been converted from a internal slave to a external. the external doesnt seem to have a bleed screw but im pretty sure i have it completly bleed out. now the problem - replaced fluid and bleed clutch which looked like it had small rubber parts in the fluid then every thing was fine for a few hours in the mud (not much gear changing) then the clutch wouldnt disengage with out pumping the peddle. bleed again and again got about 1 hour out of it. the slave isnt leaking so im wondering if the master cyclinder is the problem. any ideas.
