Rear spring not seated correctly?
Jason4x4
I was looking at my TJ earlier and I noticed that the passenger side rear spring doesn't seem to be centered in the cup at the top. It looks like it's not seated properly. The drivers side looks ok. Is this normal or should I be concerned about this?
Here's the best picture I have of it right now.
There is no spring clip to keep it from shifting around a little, it should be fine.
Ok, thanks. I have extended bumpstops so I'm not worried about it completely coming out but I noticed the driver's side looked centered and that one looked off so I wasn't sure if it was a problem.
