mud4feet
Ok....had enough of this. Your original post was titled "2000 Jeep Wrangler...." and then the text of your post said "2000 Jeep Cherokee...." ?!?! Which is it? Different animals. And then you dis'd Bounty Hunter. Not good. Bounty probably has forgotten more than I know about Jeeps. Then you mention this "trans. sync. device"?!?! And now it's a "transmission crank position sensor"?!? Hard to help someone when given this info.....just sayin'. And I have no idea what a "Senior" mechanic is.....I know I'm not one....but maybe you should just go to a "stealership" if you want a "Senior" mechanic. Good luck with your woes.
